LR2 Unknown starting problem
Old Feb 27, 2024 | 10:16 AM
cp2532's Avatar
5th Gear
Default LR2 Unknown starting problem
Hi all, I'm new and completely lost. I have a 2010 LR2. The car has been to 2 garages and they cannot diagnose the problem (the second being the regional authorized Landrover Garage).
When the engine is cold, I have no trouble starting.
When the engine is at temp having been driven a short distance, if I stop the car, the car will not restart. The starter will turn over, but it's as if the fuel isn't being fed to the engine and doesn't fire.
If I open the bonnet, let the hot air out and cool the engine slightly, then the car starts.
For a while I thought it was an air flow issue, as the car seemed to start when I opened the air filter cover - but recently I have just left the bonnet open and have the same effect.
Any suggestions, thoughts?
Thanks so much
Old Feb 28, 2024 | 06:09 AM
OldKarz's Avatar
Which engine? How far is 'a short distance'?
Old Feb 28, 2024 | 06:12 AM
cp2532's Avatar
5th Gear
Thanks for your reply, its the 3.2l petrol. The short distance can be anything that makes it warm; 10 mins (2 junctions) on the motorway; 10 mins of city driving.
thanks
Old Feb 28, 2024 | 06:16 AM
OldKarz's Avatar
MAF and intake air temperature are the likely culprits, both are the same unit I believe. Get the appropriate cleaner and and give that a go.
Old Feb 28, 2024 | 06:24 AM
cp2532's Avatar
5th Gear
Thank you. Cleaner bought on amazon, will arrive tomorrow. I've found a video of the job for an LR3 on you tube - hopes its similar. Will update in a couple of days...
Old Feb 28, 2024 | 08:50 AM
ThorInc's Avatar
Try not to get any spray on the rubber gasket or ring if possible. In addition, the screws that retain the sensor are screwed into plastic (same with air box cover), they just have to be snug.
Old Feb 28, 2024 | 12:00 PM
merlinj79's Avatar
If those sensors are that dirty, there might be a reason... if cleaning it fixes the problem look for air leaks around the filter, missing filter, and oil contamination in the intake system.
Old Feb 29, 2024 | 06:57 AM
cp2532's Avatar
5th Gear
Appreciate all the tips, thank you so much. Liqui Moly cleaner just arrived. Lets go
Hamza89
LR2
13
Apr 10, 2023 06:37 PM
abfoster
Jun 25, 2022 09:14 AM
rkashyap
LR2
Dec 23, 2021 07:00 AM
Seifert
LR2
22
Sep 27, 2021 07:10 AM
nr1416
LR2
13
Jun 27, 2014 05:12 AM
