2008 LR2 won't rev over 4000 rpm
Old Sep 13, 2021 | 04:44 PM
Seifert's Avatar
7th Gear
Default 2008 LR2 won't rev over 4000 rpm
Hi guys.
I have a 2008/09 LR2 3.2 with 79.000 km (I´m from Brazil, so...metric system here!), but it's around 50.000 miles on the clock and I bough the car from the first owner. So it is in very good shape and was well maintened.
I noticed sometime ago that the engine won't rev over 4000 RPMs. Around 3.500 RPMs, the engine seems to lose some power and at exactly 4000 rpm, it cuts off and the next gear is engaged. The car works perfectly fine on low RPMs, so it's not a huge problem, but it bothers me A LOT when I drive on the highway.
The engine management light doesn't flash at any time or the car runs rough or has problems to start. Cold or hot, the car works fine.
Soon after the car came to me, I bought new spark plugs, changed the engine oil and did some basic maintenance, but the issue appeared before this.
Does anybody had similar issue?
A friend has a Volvo V60 T6, and as the coils and position camshaft sensors are the same, we tried to this parts in each other cars and, just my LR2 keep 'limited' to 4.000 RPM.
If anybody has a tip, I'd appreciate! Thank you.
Old Sep 13, 2021 | 08:35 PM
flybd5's Avatar
Oi Seifert, este é um novo para mim. Você conectou o carro a um leitor de código para ver se o computador lhe diz algum código de erro? Pode ser um problema de pressão de combustível.
Old Sep 14, 2021 | 09:40 AM
Seifert's Avatar
7th Gear
I've tried the launch scanner and the only error code was related to the camshaft position sensor, probably an old register.
I'm waiting for a specialist have a spot in this shop to read the parameters with the official Land Rover scanner. There's only one dealership in a reasonable distance from my home here where I live, and they simply deny some kind of services for cars with certain 'age'. We brazilians are used to that, unfortunately...
I'll try to measure the fuel system pressure while I'm waiting for this guy.
Some more info...If I press the gas pedal while in P or N, the same happens. It cuts @4.000 RPMs. And it happens pushing the pedal to the maximum or not, so I'm guessing it's something electronic.
Old Sep 14, 2021 | 02:09 PM
ThorInc's Avatar
I'll just throw this out there, if there are no codes, is there a "T" anywhere on the dashboard, even where the auto gears are listed on the dash?
Old Sep 14, 2021 | 02:16 PM
Seifert's Avatar
7th Gear
No, there isn't.
Just the " i" when in Sport or manual mode.
I'll use the car later and make some videos/pictures.
Old Sep 14, 2021 | 02:55 PM
ThorInc's Avatar
Originally Posted by Seifert
No, there isn't.
Good, that eliminates the vehicle from being in Transport mode which actually limits the rpm to under 3000, if memory serves me.
You need to hook it up to a proper LR code reader and check for codes, Sounds like some type of governor thing happening.
Old Sep 14, 2021 | 04:14 PM
flybd5's Avatar
That's what I said, but in Portuguese. (Learned it in thirty days in Säo Paulo, nine hours a day, burned out four individual instructors, while at the same time admiring the ability of Brazilian girls to wear spray-on jeans...)
Old Sep 15, 2021 | 09:46 AM
merlinj79's Avatar
The fuel pressure sensors have a failure mode that often involves limited power at highway speed, but 4000 rpm is pretty specific. Maybe swap that with your buddy's volvo too, takes about five minutes (it's on the end of the fuel rail).
Old Sep 15, 2021 | 12:15 PM
flybd5's Avatar
If there is a crankshaft sensor code that may be related. Clear the code, then run the engine for a while, press the accelerator a bit, then read the code again.
Old Sep 17, 2021 | 12:48 PM
Seifert's Avatar
7th Gear
Eu pensei que o google tinha traduzido automaticamente para mim!
Our girls are the best!!
I just filmed what it happens with the car. Here's the link on youtube:
You can see at exactly 4k rpm, the 'rev limiter' acting.
I´ll try to replace the fuel pressure sensor. My friend that has the Volvo is out of town, but he'll be back on sunday. While I can't hav an a appointment with the LR 'specialist', I'll try your sugestions.
Thank you guys!
