Main Head lamp not coming on
Old Mar 14, 2026 | 01:13 PM
Nassau1973's Avatar
6th Gear
Default Main Head lamp not coming on
My 2012 LR2 main headlight not coming on. Switched the 15 A fuse on the passenger side but still not working. Any suggestions are appreciated
Old Mar 14, 2026 | 04:26 PM
ThorInc's Avatar
Are they adaptive HIDs? If so there is a ballast on the underside of the entire light assembly. I have a 2008 with HIDs but I don't know what 2012 came with?
Old Mar 14, 2026 | 05:10 PM
Nassau1973's Avatar
6th Gear
Thanks for responding. No they are not HIDs.
Old Mar 15, 2026 | 07:52 AM
ThorInc's Avatar
Try a search over at freel2.com, a UK site. The Freelander 2 is the European version of the LR2 with more engine options.
Old Mar 15, 2026 | 10:13 AM
flybd5's Avatar
Have you tried a new lamp?
Old Mar 15, 2026 | 11:55 AM
Nassau1973's Avatar
6th Gear
Yes, I switched out the lamps on both sides first.
Old Mar 15, 2026 | 04:26 PM
flybd5's Avatar
Which mode of the headlamps is not working, high or low?
Old Mar 15, 2026 | 06:25 PM
Nassau1973's Avatar
6th Gear
Low beams not working. High beams are fine.
Old Mar 15, 2026 | 07:01 PM
flybd5's Avatar
It's either relay R127 inside a module in the main junction box, or the control on the steering stalk.
Old Mar 15, 2026 | 09:54 PM
Nassau1973's Avatar
6th Gear
Which one is R127? Or is there another place i should look?
