Main Head lamp not coming on
Old Mar 15, 2026 | 09:57 PM
flybd5's Avatar
Originally Posted by Nassau1973
Which one is R127? Or is there another place i should look?
You are looking in the wrong place. R127 is not a standalone relay. it sits inside another module in the Central Junction Box, behind and under the glove compartment. I will have to look it up in the service manual.
Old Mar 15, 2026 | 10:24 PM
flybd5's Avatar
Ok, bad idea to tell you to look for any relay. It's on the PCB of the CJB and is not something you can replace. The relay is actually of the FET type which cuts power if it detects an overload, but restores it if the overload goes away or the temperature returns to normal. So forget about that.
The service manual says that after checking for a bulb failure, blown fuse or circuit fault, there are two other options: the lighting control switch on the lower left side of the dashboard, or the Left-hand steering
column multifunction switch. I've never seen the lighting control switch fail, but I have heard of the steering column multifunction witch failing. I would suggested cleaning both first with electronic contact cleaner.
Leebop777
LR2
Sep 24, 2025 06:45 PM
nzy604
LR2
Feb 12, 2025 08:45 PM
Chillidigger53
Freelander
Jan 3, 2024 12:01 PM
kylltyme1
Dec 20, 2019 04:09 PM
dagger987
LR2
Feb 18, 2015 10:08 AM
