Narrowing a transfer case vs cv axle issue
Old May 17, 2023 | 07:14 PM
dcnaz's Avatar
3rd Gear
Default Narrowing a transfer case vs cv axle issue
I have a 2012 lr2 with 75k, when i turn while still in my driveway there is a binding feeling on front, i see some play in front passenger side axle on the inner boot, before the carrier holder in middle. Its almost out but do i need to remove the carrier bolts to the engine? Or will it just come out of transfer case and then through the round hope in the carrier? Also, if i remove it from transfer case and then drive it and the binding is gone how do i go about knowing if its the axle or transfer case issue. No codes, no other issues
Old May 17, 2023 | 07:27 PM
flybd5's Avatar
I strongly suggest you download the service manual and carefully study the sections on the front halfshafts and the front transfer case before doing anything. Stop driving the car before you do more damage. That should be obvious.
Old May 17, 2023 | 07:50 PM
dcnaz's Avatar
3rd Gear
All i did was ask a question. Never mind, i will figure something out.
Old May 17, 2023 | 08:49 PM
flybd5's Avatar
And I pointed to the answers. Since you can obviously read, I think you should do as i suggested. Or you can "figure something out." <shrug>
Old May 17, 2023 | 09:09 PM
dcnaz's Avatar
3rd Gear
If i could found it in the manual i would not have been here dumbass. I ask questions in all type of forums this is definitely the most retarded. You must be 90. I will get it figured out <shug>
Old May 17, 2023 | 09:10 PM
flybd5's Avatar
Don't let the door hit you in the ***, nimrod.
SWAINROVER
Dec 5, 2015 04:38 PM
june82000
Sep 27, 2015 07:03 PM
cornbreadj
Apr 5, 2015 09:20 PM
Walko327
Mar 28, 2013 08:43 AM
ajh
Oct 23, 2006 09:42 PM
