New LR2 owner. Replacement parts questions
Old Feb 14, 2020 | 10:18 AM
colt4irish's Avatar
4wd High
Originally Posted by Jade Dockery
I painted my side vents. Simple job... also painted my trim pieces and the front grill (that was a bit frustrating) https://saclandrover.niello.com/acce...-sacramento-ca
its hard to find aftermarket replacement parts for me too. The fog light bulb is H11, wish I could help more.
jade - thanks for the info. What kind of paint did you use to repaint side pieces and grill? Any photos? Thank you in advance!
yeah - I’m thinking I will replace the tail light assembly and fog light assembly and the rest just try to repaint.
Old Feb 14, 2020 | 12:55 PM
Jade Dockery's Avatar
I tried to add pictures twice it keeps telling me cannot download. I used the rustoleum 2x coverage without primer but did use an enamel clear coat. Smooth finish and has been going strong for a few months now without any bubbling or chips. My only con is don’t let wax touch it. And wish I had did more glossy finish. What’s your email and I can see if it will let me email them.
Old Feb 14, 2020 | 01:07 PM
ThorInc's Avatar
Use any plastic recommended paint, Rustoleum is good. If you google how to paint plastic, there are tons of vids on Youtube. Clean it well, use a scotchbrite pad to lightly scuff, clean again, use a mild plastic adhesive coat and then apply a few coats of your paint. You can seal with clear or semi gloss. If you apply thin multi-coats before the previously applied coat is not fully dry then you can get away with light scuffing, cleaning and paint only. The Powerful UK site above has a video on how to re & re the side grills, I'd recommend watching how they remove it as my first instincts likely would have broken at least one of them .
Old Feb 14, 2020 | 01:33 PM
colt4irish's Avatar
4wd High
colton.mason@suprememedical.com
thanks so much!
colt4irish's Avatar
4wd High
awesome info! Thank you.
rdlevy1215
May 29, 2020 07:08 PM
ArmyRover
Jan 30, 2020 11:14 PM
oliver1071
LR2
22
Oct 16, 2019 08:18 PM
EricTyrrell
Sep 4, 2013 09:40 PM
sendmail
Feb 4, 2012 10:14 PM
