P2402 Code
Old Jan 15, 2020 | 09:47 PM
Kevin Chambers's Avatar
Default P2402 Code
I am getting a P2402 code on my 2013 LR2 (4 cyl turbo charged, approx 32,000 miles). The error occured not long after I filed up the gas tank. Does anybody know where the leak detection pump is located on this car. I have been advised to first check the electrical connections, but I can't find the pump.
Thanks !
I am wondering if this fault code could be caused by a faulty. It first appear about 20 minutes after I filled the car up. It persisted through the next fill-up, but on the third fill-up I drove about 150 miles (all freeway) with n problem. After the last fill-up it re-appeared. I would hate to start taking things apart if the fix is a simple gas cap changeout.
Thanks!
Old Jan 16, 2020 | 10:42 AM
ThorInc's Avatar
https://landroverforums.com/forum/lr...on-pump-98459/
Was on a thread I think you may have also created?
I would replace the gas cap and reset the code if you have that ability with a scanner first.
emncfi
Mar 6, 2018 03:35 PM
bcolins
Mar 9, 2017 01:20 PM
pwaltrip
Jul 26, 2016 10:00 PM
philiplarson
Jul 3, 2009 05:24 PM
