Engine Code 440
Old Jan 1, 2009 | 06:16 PM
philiplarson's Avatar
Default Engine Code 440
I installed a new MAF to correct the codes 171 & 174, after about 225 miles the code 440 popped up.
Phil
2000 Discovery 85K, great LR
Old Jan 1, 2009 | 06:33 PM
Default RE: Engine Code 440
Is it 0440? 1440? What?
The only 440 I found is a 1440 and it is a EVAP fault, check and make sure the gas cap is tight.
Old Jan 1, 2009 | 06:37 PM
Randy P's Avatar
P0440 is a General Evap failure that the computer can't diagnose the exact issue on it's own. Typically a gas cap will give you a large leak code, not the general failure. Make sure you didn't leave a vacuum hose disconnected that attaches to the purge solenoid/intake manifold.
Old Jan 1, 2009 | 06:41 PM
It was PO440 and not 1440, I removed the gas cap and reinstalled. This may have been the problem. I filled up before the code showed up, about 40 miles latter. I will drive in the morning and post what happen if anything at all.
Old Jan 1, 2009 | 06:52 PM
Randy P's Avatar
If the gas cap was the issue the light will turn itself off after a few drive cycles.
Old Jan 1, 2009 | 06:54 PM
440 is a evap system failure not a leak as in a gas cap being off or loose.
A mechanic may be in order unless you are very familiar with trouble shooting the evap system.
Old Jan 3, 2009 | 07:34 AM
It was the gas cap not being tight. Thank again for the feed back.
Phil
Old Jan 3, 2009 | 08:28 AM
I hope you are right, but that 440 code is a malfunction code not a leak code for the evap. If it comes back, you will need to look more into a complete evap malfunction.
Good luck.
Old Jul 3, 2009 | 05:24 PM
Disco TN's Avatar
Question Same Code 0440
I just got this code, have cleared it with scanner, filled tank drove it came back, check gas cap it was tight, have cleared it three times, where should I start looking for the problem ?
thanks
Doug
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
