Rear wheels engagement
Old Jun 25, 2022 | 04:43 PM
abfoster's Avatar
Default 2008 lr2
I will take a PDF OF THE LR2. You can send it to: mrfoster42@gmail.com
Old Jun 26, 2022 | 12:35 AM
merlinj79's Avatar
Too big to email, but you should be able to download it from here: https://www.freel2.com/forum/topic10621.html
The manual covers both i6 and diesel engines, so make sure you're in the right section for engine stuff. Most other systems are common.
Old Jun 26, 2022 | 08:34 AM
flybd5's Avatar
Check your email.
Old Jun 26, 2022 | 02:10 PM
ThorInc's Avatar
Also, check the haldex fuse while you are at it, easy fix if.....
Old Jun 27, 2022 | 07:32 AM
guy's Avatar
guy
I was reading somewhere that the splines had stripped on the drive shaft to differential end. Leads to the question, HOW does one do that?!
Old Jun 27, 2022 | 07:38 AM
flybd5's Avatar
One way to do that is to have a bad u-joint that has too much play, hearing the "thunk!" when moving out and not doing anything about it. Eventually the thunks pile up and the splines are damaged.
r_cragg
Mar 29, 2021 09:45 AM
THuck
Oct 26, 2019 02:57 PM
Cobra11
Dec 13, 2016 03:53 PM
Big Jim Swade
Nov 18, 2011 02:28 PM
radshop
Tires
May 28, 2008 06:53 PM
