Rear wheels engagement
I will take a PDF OF THE LR2. You can send it to: mrfoster42@gmail.com
The manual covers both i6 and diesel engines, so make sure you're in the right section for engine stuff. Most other systems are common.
One way to do that is to have a bad u-joint that has too much play, hearing the "thunk!" when moving out and not doing anything about it. Eventually the thunks pile up and the splines are damaged.
