Recent Engine Issues
Old Mar 5, 2021 | 10:41 PM
Rick Nelson's Avatar
4wd High
Default Recent Engine Issues
So I went to start my vehicle the other day, immediately when it started it began vibrating as if there was a decent misfire or timing issue in the engine. I immediately got something along the lines of "decreased engine performance or power" on my message centre. Then the car started "bogging" heavily at idle and then check engine came on and remained solid so I shut it off.
Today I had borrowed a friends OBD2 to try and diagnose the issues, got a P0301 Cylinder 1 Misfire, P0351 Ignition Coil A Primary/Secondary Circuit and P0420 Catalyst System Efficiency Below Threshold (which I assume is the Bank 1 O2 Sensor) But the concerning part was after I had finished grabbing the codes and disconnected the OBD, I went around to the front of the vehicle and there was a decent amount of electrical smoke coming from the Far left (passenger side) Coil Pack.
Any one with any advice? oping it's not too expensive of a repair maybe DIY? Don't want to sink more into the car than what it's worth.
Old Mar 5, 2021 | 11:03 PM
flybd5's Avatar
You might want to start by telling us what model and year you have. How do you know it was electrical smoke? Did you check to see what was smoking?
Old Mar 5, 2021 | 11:10 PM
4wd High
Duh.....long day. 2008 LR2 SE, Electrical Smoke has a very distincive smell, and as stated in my post the smoke was billowing from the far left Coil Pack
Old Mar 5, 2021 | 11:27 PM
flybd5's Avatar
P0301 and P0351 likely indicate you lost the #1 cylinder ignition coil. The smoke makes it even likelier. If that's the case, the coil is easily replaced and is a no-brainer DIY. Disconnect the battery, remove top engine snap-on plastic cover, remove single bolt, GENTLY unplug (you don't want to ruin the plug and have to replace the entire harness) and pull the coil out from the spark plug. Reverse to install. You can do that single one, but I would recommend that you change all six, so as not to tempt Murphy, seeing as he has already paid special attention to #1. A set only costs about $70-$90 on ebay.
If you choose to do all this kindly let us know how it all turns out.
Old Mar 5, 2021 | 11:29 PM
4wd High
Cheers for the input, i figured I was just going to grab a 6er of coils...and beer, might as well change the plugs while i'm at it. Hoping for positive results!
Old Mar 5, 2021 | 11:33 PM
flybd5's Avatar
Plugs and beer are a good idea too, just do the DIY first and then celebrate with the beer when it fires up without smoking.
Old Mar 6, 2021 | 10:34 AM
merlinj79's Avatar
Yeah all those codes strongly hint coil #1. The CAT code is because the fuel is not getting lit, but rather dumped raw into the exhaust.
For plugs I'd recommend the Denso Platinum 4704 Twin Tip. I liked them so much I put them on my acura too, noticeable boost in power on both cars and the acura's old NKG plugs were were in still in good shape with only 50k miles (half the change interval).
https://landroverforums.com/forum/lr...lug-gap-76767/
Snafu / Disco Fries
Aug 13, 2017 11:04 AM
detroitmike
Jul 2, 2016 10:15 PM
SoCal Rob
Nov 26, 2015 10:18 PM
cipher982
Nov 21, 2012 10:08 PM
Schaefer.v
Jun 15, 2010 02:48 PM
