Reducing heat and Reinforcing Firewall
Old Jul 1, 2020 | 03:29 AM
timfromzim's Avatar
Lightbulb Reducing heat and Reinforcing Firewall
Good Morning,
I am busy doing up my Land Rover Series 2A 1965. I am wanting to insulate the inside of the car as the firewall get painfully hot.
What would the community recommend as a good insulator for the firewall?
Thanks in advance
Old Jul 1, 2020 | 05:35 AM
ThorInc's Avatar
This specific LR2 forum might not give you the access to the entire forum knowledge for the Series 2A.
Old Jul 1, 2020 | 07:21 AM
flybd5's Avatar
I can only recommend what I used on aircraft, a ceramic blanket. I used it to insulate an exhaust tube from a turbine engine on an aircraft I owned. Worked great.
Amazon Amazon
But you really should check in the forum for your vehicle.
Old Jul 1, 2020 | 04:17 PM
flybd5's Avatar
Oh and keep in mind that insulation does not dissipate heat, it just prevents its transfer. When you do that it will stay in your engine compartment. You should consider that in whatever you do. There should be a way to dissipate the heat out of the engine compartment.
mirepoixmatt
Oct 17, 2016 08:20 AM
Adam Horak
Feb 9, 2015 04:15 PM
scol354412
Aug 13, 2014 10:16 AM
jmanborges
ROAMING WITH FRIENDS
Oct 3, 2012 09:50 AM
SeriesDude69
Other
Oct 27, 2009 10:59 AM
