Replacing Rear Wiper Motor..Does It Fix Rear Washer Fluid?
The rear wiper motor has nothing to do with the rear washer fluid. There is only one washer fluid pump for the front and rear windshields and the headlight washers, and it is located behind the RH fender splash shield, below the washer fluid reservoir. Try blowing low pressure air on the fluid lines to see if they are clogged.
Rear Screen Washer
On receiving a request for rear screen washer operation the CJB will energize the rear washer control relay. This allows a
battery voltage feed to flow to the washer pump. A ground path for the pump is provided by the de-energized front washer
control relay. Reversing the polarity of the pump (see 'Windshield Washers' above) allows washer fluid to be directed to
the rear screen washer jet rather than the windshield washer jets. The rear screen washer jet is incorporated into the high
mounted stop lamp.
The rear screen washer will operate for up to 10 seconds if continuously requested. When rear screen washer operation is
requested, the rear screen wiper will operate continuously until the switch is released. After the switch has been released,
or following 10 seconds of continuous operation, the CJB will operate the rear screen wiper through 2 or 3 more wipe
cycles.
mounted stop lamp.
cycles.
ThorInc (08-15-2020)
hilltoppersx
09-22-2010 07:44 PM
