Replacing Rear Wiper Motor..Does It Fix Rear Washer Fluid?
Old Aug 14, 2020 | 05:41 PM
Rick Nelson's Avatar
4wd High
Default Replacing Rear Wiper Motor..Does It Fix Rear Washer Fluid?
I need to replace the rear windshield wiper motor...just wondering if this in turn will fix the rear wiper fluid as it doesn't seem to spray....but the front works just fine...or is there a separate reservoir for the back?
Old Aug 14, 2020 | 06:27 PM
flybd5's Avatar
The rear wiper motor has nothing to do with the rear washer fluid. There is only one washer fluid pump for the front and rear windshields and the headlight washers, and it is located behind the RH fender splash shield, below the washer fluid reservoir. Try blowing low pressure air on the fluid lines to see if they are clogged.
Old Aug 14, 2020 | 06:58 PM
4wd High
Thanks for the input...is the rear fluid nozzle integrated in the flathead screw that is located on the rear centre brake light?
Old Aug 14, 2020 | 07:13 PM
flybd5's Avatar
Rear Screen Washer
On receiving a request for rear screen washer operation the CJB will energize the rear washer control relay. This allows a
battery voltage feed to flow to the washer pump. A ground path for the pump is provided by the de-energized front washer
control relay. Reversing the polarity of the pump (see 'Windshield Washers' above) allows washer fluid to be directed to
the rear screen washer jet rather than the windshield washer jets. The rear screen washer jet is incorporated into the high
mounted stop lamp.
The rear screen washer will operate for up to 10 seconds if continuously requested. When rear screen washer operation is
requested, the rear screen wiper will operate continuously until the switch is released. After the switch has been released,
or following 10 seconds of continuous operation, the CJB will operate the rear screen wiper through 2 or 3 more wipe
cycles.
joshjellel
Aug 1, 2020 11:29 PM
OffroadFrance
Feb 21, 2014 08:40 AM
junior496
Jan 26, 2011 05:28 PM
hilltoppersx
Sep 22, 2010 07:44 PM
esaycho
May 11, 2006 07:29 PM
