Spark plugs
Old Mar 28, 2022 | 12:41 AM
ourx15's Avatar
Default Spark plugs
Hello everyone. Hope I’m not starting a “discussion”. What spark plugs are you using in the 2.0l 4cyl turbo? I was going to go with iridium, just wondering what others think?
Old Mar 28, 2022 | 09:44 AM
flybd5's Avatar
The Land Rover OEM spark plugs for your engine (p/n LR005483) are actually Champion EON Titan spark plugs, not Iridium-tipped.
Old Mar 28, 2022 | 10:07 AM
guy's Avatar
guy
And they are good plugs at that.
Old Apr 6, 2022 | 08:25 PM
flyingscot's Avatar
Default denso irridium
Hi - I recently installed dense iridium plugs - idea being that they will also longest, best spark, etc..... So far so good.
Amazon Amazon
I had just before replace the plugs in our land cruiser with same and had a good result, therefore did same for LR2.
Old Apr 7, 2022 | 09:26 AM
merlinj79's Avatar
I've been using the Denso iridium TT on all of my vehicles... noticeable boost in power.
Old Apr 7, 2022 | 09:38 AM
flybd5's Avatar
The thing with iridium plugs is that the are much more expensive than platinum plugs, and any performance increase is barely noticeable. For me it's more a six of one, half a dozen of the other type of thing.
Old Apr 7, 2022 | 12:06 PM
p_gill's Avatar
Merlin,
I am also using the Iridium TT plugs or Iridium Power on every car that I own that Denso makes an appropriate plug for.
Note: for my 3.2 I have a pack of TTs on the shelf waiting to upgrade from the Iridium Power (Single fine wire)
Here is what I think about the Iridium TTs
1. The fine wire tip makes it easier for the spark to jump the gap
- The ECU will adjust the power output of the coil to minimize misfire events
----- Even though the ECU can compensate doing so will shorten the life of your coil packs
-------- i.e. your engine can operate at Redline. Would you operate it that way 100% of the time and expect the engine to last 500K miles?
2. The TTs are advertised as reducing quench (Flame starts but get extinguished)
- The ECU will log these events as misfires
----- These misfires will affect the monitoring of the catalyst efficiency (make it more likely for a good CAT to fail and set a code)
- When the Catalyst efficiency is checked the ECU commands a lean mixture then rich then lean to see how much O2 the CAT stores
----- Lean Mixture are more difficult to ignite
------- The TT will be more likely to ignite the lean mixture consistently
---------- Volvo on the 3.2 and 3.0T switched to the TT plugs from the Iridium Long-life after 2011
------------- The TTs are more expensive than the Long-life so my assertion is that Volvo had a reason to do this
3. I think of the TTs as a performance device that has the side benefit of improving emissions
Here is what I would get if I owned a 2.0T
Iridium TT 4719 (ITV20TT) Gap 0.040 2013 Land Rover LR2 SE L4 2.0L
https://www.densoautoparts.com/find-...#searchResults
Good luck
Paul
2013 Land Rover LR2 SE L4 2.0L2013 Land Rover LR2 SE L4 2.0L
Old Apr 7, 2022 | 02:19 PM
flyingscot's Avatar
Paul - thx for all the tech background - I had no idea - my objective was to use the Iridium plugs for longevity - the one you recommend is what I put in my 2.0L T. Hoping to get at least 100k miles from them.
Old May 17, 2022 | 08:36 AM
flyingscot's Avatar
Default time for new plugs..... general interest
OK - after all the maintenance on the LR2 my conscience was suitably pricked & I started on the much loved and neglected family beater - 04 Yukon 6.0L V8 - suspect the plugs have never been changed (ever) - now at 196k miles (Champion Iridium). Had noticed some rough idle but nothing show-stopping.
old & new - old 196k miles (suspected) - Champion Iridium
Old May 17, 2022 | 08:39 AM
flybd5's Avatar
Dude... you need to start reading the maintenance schedule sections on your vehicle owner manuals.
