Suspension Recommendations?
Old Sep 11, 2020 | 03:28 PM
Rick Nelson's Avatar
4wd High
Default Suspension Recommendations?
Need to replace the suspension in my '08 LR2 as it's getting a little bouncy after hitting a small bump when i drive.
Any recommendations for a specific brand or kit for after market suspension and/or lift kit?
Is the suspension removal/installation doable by ones self with basic tools?
Cheers,
- Rick
Old Sep 11, 2020 | 05:23 PM
p_gill's Avatar
Rick,
Watch the video
Does it look like something you have done before?
Good luck
Paul
Old Jun 9, 2023 | 09:17 PM
Thorsond81's Avatar
Cheers,
- Rick
How did this go? Did it fix your problem? I am ha ing the same issue, but am worried there might be more wrong than just the struts.
Old Jun 10, 2023 | 03:13 PM
merlinj79's Avatar
Check front control arms.
Old Sep 13, 2023 | 03:50 PM
dregill's Avatar
I had my system replaced with SF Racing coil over shocks. I could have done the job, but would have rented a spring compressor to remove the coils. I preferred to have a shop do that. The shocks cost $1000, not sure of how much it was to install as there was a number of other items on the bill. I shocks made it about three inches higher (I would like to lower it about 1-2 inches, back to closer its original) and I softened the ride 4 clicks. I probably would be a little better another 4 clicks softer.
Old Sep 14, 2023 | 09:55 AM
merlinj79's Avatar
I had Bilstein B4 shocks installed. Stock height, and just a tad firmer than OEM. Wife and I like the ride better than the OEM.
Old Jan 4, 2025 | 06:12 PM
lazerbrains's Avatar
Did you have them installed or put them in yourself?
If you had them installed, how much did it run you?
Old Jan 6, 2025 | 10:25 PM
merlinj79's Avatar
I had them installed, don't recall how much. I don't think it was crazy money.
Old Jan 6, 2025 | 10:43 PM
What’s your definition of “crazy money”? I got a quote for about $2200 for both front and back.
Old Jan 7, 2025 | 10:21 AM
merlinj79's Avatar
It was probably something like that, I'd remember if it was much more (I'd have done it myself).
