Tail gate
Old Aug 28, 2024 | 03:26 PM
phyther68's Avatar
Default Tail gate
Unlocking the tail gate from the inside. Tried pressing both lock and unlock button by hazard light and did not work. Annoying to use the remote to unlock . Any advise. 2012 land rover LR2 HsE. Thank you
Old Aug 29, 2024 | 11:25 AM
merlinj79's Avatar
That's odd. Usually the failure is either the switch on the tailgate or the lock mechanism itself.
There may be a valet switch in the glove box to activate/de-activate the dash buttons for that function? My wife is on a trip with our LR2 or I'd check for you.
But you can also open the tailgate using the rubber covered switch on the tailgate. It's under the lip above the license plate. This switch only works if the vehicle is already unlocked.
Old Aug 29, 2024 | 07:50 PM
flybd5's Avatar
You are aware that the unlocking is not immediate, right? It takes 2-3 seconds and then it unlocks.
Old Sep 4, 2024 | 07:47 AM
guy's Avatar
guy
I'm still trying to think this through. Unlocking from the inside... Annoying to use the fob...
Oh, you're sitting in the driver's seat and someone else is loading the back?? I believe the gear selector must be in P (a safety precaution) . Do the console buttons work if the ignition is not on?? I'll need to check that.
Old Sep 4, 2024 | 08:31 AM
flybd5's Avatar
Yes. They do.
EscapeSharkCity
Mar 17, 2022 05:31 PM
spannermonkey
May 29, 2020 02:43 PM
marcuskilgore
Oct 6, 2019 03:48 PM
Prowler9876
Feb 22, 2010 08:33 AM
Hutchings
Jan 30, 2007 01:39 PM
