Used 2008 land rover lr2
Old Nov 15, 2022 | 04:14 AM
tangodog83's Avatar
3rd Gear
Default Used 2008 land rover lr2
So i just bought a 2008 Land Rover LR2 Se at a auction. Love the car so far but one major issue. They only had one key fob and its completely dead. I cant lock or unlock the vehicle. Also the Key that is supposed to come with it i did not get and the auction house says they dont have it. I spoke to a dealership and its gonna cost me over $800 to get a new key fob and key programmed and cut. So my question is doesnt anyone know of any cheaper ways to do it? Any help would be greatly appreciated!
Old Nov 15, 2022 | 09:50 AM
p_gill's Avatar
Let's assume that you can use the key to start the engine
If the ECU went into deep sleep mode then you may need to wake it up. For my LR2 this happened with the Alarm set and using the emergency key triggered the Alarm but once I got inside the vehicle and started the engine everything was fine.
https://www.freel2.com/forum/topic37...ht=key+battery
The battery in the key fob can be replaced but it requires you to cut open the shell (and you will need a new battery and a new shell)
https://www.freel2.com/forum/topic32...ht=key+battery
Let us know what you find out
Take care
Paul
Old Nov 15, 2022 | 11:01 AM
merlinj79's Avatar
I assume the key starts the car, but just won't do remote functions?
If so, you can program a new key, there are $30 ish aftermarket keys available. You need software, many of us have used the Autel AP200 which connects to the OBD2 port ($60-ish). You can also get a bootleg copy of the land rover SDD software, but that requires special hardware.
The AP200 software is a little bit funky but I've used it twice successfully. Info in this thread, towards the end of the thread...
https://www.freel2.com/forum/topic10...8a1ebd1e895bd6
Old Nov 15, 2022 | 11:03 AM
ThorInc's Avatar
Try this if you have the one fob but the fob battery or auto battery is dead:
Old Nov 15, 2022 | 04:11 PM
flybd5's Avatar
The FOB can be carefully popped open and the battery replaced (if I remember correctly it is a 2032) but you have to carefully unsolder the contacts and then solder them again with the new battery. The FOB can then be closed up again (or glued back together). That will allow you to lock and unlock the car. You can also buy a third party FOB and reprogram it for your car, but be careful about doing that. I paid $120 to the dealer to do it because I wasn't sure how many FOBs had already been programmed for it and there is a limit how many you can program to the car.
Old Nov 15, 2022 | 04:39 PM
merlinj79's Avatar
There is a limit but it's pretty high, 30 or something like that. Mine has had 4-5 new keys since I got it, and it was four years old then. So worst case maybe another 4 keys that I don't know about? So less than ten keys in 14 years.
But once again you have to wonder what JLR was even thinking??? Why have an upper limit? And what happens if you reach it? Buy a new ignition dock module?
Old Nov 15, 2022 | 05:08 PM
flybd5's Avatar
You sure about that? I thought the JLR/SDD software said it was much lower than that, but I haven't checked it lately.
Old Nov 15, 2022 | 06:53 PM
merlinj79's Avatar
Pretty sure.
IIRC, there's a max number which can be programmed at any one time, single digits? Then there's a higher lifetime cap on keys, why FFS I don't know.
Old Nov 15, 2022 | 10:09 PM
tangodog83's Avatar
3rd Gear
Thanks all for the responses. So I dont actually have the emergency key. The top of the key fob is broken off and there is no key there. I am able to start and drive the car just cant lock and unlock. Im also worried if something ever goes wrong and i need the emergency key i dont have it. Ill have to look into buying a new fob and trying to reprogram it. They key its self is the problem and most expensive thing apparently.
Old Nov 16, 2022 | 12:02 AM
merlinj79's Avatar
Yeah, you'll want the mechanical key. The dealer can cut that based on the VIN. I suspect the dealer will charge you for a new fob, programming, and everything.
A locksmith *might* be able to cut one; you'll have to ask them.
The aftermarket fobs which I've purchased did come with a blank mechanical key.
