What this could be?
Old Jun 24, 2024 | 12:03 PM
RICKDO's Avatar
Default What this could be?
Power steering fluid goes straight to the ground on the opposite side of the reservoir.
File Type: mov
Old Jun 24, 2024 | 02:44 PM
LR2driver's Avatar
If you are lucky, there is a leak where the hoses connect to the reservoir, and the fluid follows the hose towards the pump until it falls to the ground. It's a DIY project to replace the reservoir and reconnect the hoses.
Worst case is the power steering pump has a leak and needs to be replaced, a much bigger job.
Old Jun 25, 2024 | 12:23 PM
RICKDO's Avatar
Default Thank you!
This happened right after I got home from the shop that replaced the fuel pump and assembly ($1000 job) could this be related? Can’t avoid to think something fishy.
Old Jun 25, 2024 | 12:41 PM
LR2driver's Avatar
The fuel pump is not in the same area as the power steering. But it's possible they may have inadvertently knocked a PS hose loose from it's fitting. That would actually be a good thing, since it should be an easy fix.
This leak is much easier to diagnose when you can inspect from underneath. However, if you can't drive it to a shop because it is too low on PS fluid, and you're not comfortable diagnosing it further yourself, then you may want to have a mobile mechanic visit you.
merlinj79's Avatar
I don't they should be related since the fuel pump is in the tank (assuming 3.2 gas engine). I don't think they should have been doing anything under the hood, other than maybe connect a gauge to the fuel rail to check the pressure.
If you've never replaced the PS reservoir, you need to do that anyway... it has a built in filter which can only be replaced by replacing the res. Cheap and easy DIY.
adolfojbonilla
Sep 30, 2022 10:00 AM
Athana
May 29, 2019 07:49 PM
RHD 4 LIFE
Dec 1, 2012 05:48 PM
nanin
May 12, 2007 10:09 AM
