Where is coolant temp sensor located??? help
Old Aug 17, 2025 | 09:18 PM
Dannyo9's Avatar
4th Gear
Question Where is coolant temp sensor located??? help
Hello everyone I need help finding the location of the coolant temperature sensor on my car so I can replace it. I have a 2013 land rover lr2 and its been overrheating sometimes when its in idle. Scanner tool at O reilys popped up with the numbers implying that its either the coolant temp sensor or thermostat. If anyone could help me out i would appreciate it sooo much thank you.
Old Aug 18, 2025 | 09:39 AM
LR2driver's Avatar
Check the diagram for your vehicle. You should see it connected to the thermostat housing. If it's possbile to access the ECT sensor by removing the passenger-side headlight, you might be able to reach in and replace it. That would be a lucky break.
If you need to remove the intake manifold for access, then you're better off replacing the entire thermostat & ECT sensor while you have that area opened up. A new thermostat might come bundled with the ECT installed, you need to check.
I'm assuming you really narrowed down the overheating problem to this component and it's not a bad cooling fan or something else.
Let us know how it turns out.
Dannyo9
Aug 17, 2025 09:21 PM
Dannyo9
Freelander
pdrawdy
LR4
Jan 17, 2024 04:10 PM
Greg-2022
Sep 21, 2023 01:32 PM
rodgerste
May 4, 2013 01:13 PM
