05 lr3 overheating
Old Nov 5, 2014 | 09:04 AM
reyday's Avatar
Smile 05 lr3 overheating
Lr3 has 55,000 miles while driving it overheats but temp gauge stays in in mid point the coolant tank has milky coolant n it but the oil dip stick is clean help me please!!!!!
Old Nov 5, 2014 | 12:42 PM
willrok13's Avatar
V8 or V6?
Old Nov 5, 2014 | 04:17 PM
unseenone's Avatar
Milky coolant sounds like oil contamination, doesn't it?
I would have the coolant tested, as well as the engine and transmission oil for contamination.
Of course, thermostat, water pump (they do go), bad radiator and so on would be important to check as likely culprits as well. If you get coolant in your transmission, it will be toast.
Old Nov 6, 2014 | 06:15 AM
reyday's Avatar
Hi
Its a V8.
The truck has been to two mechanics. 1st one didn't have a clue but he did notice a hole in a hose that he changed but it only did the same thing. Once the hose was replaced.
The 2nd mechanic diagnosed it as a seal in engine. They both flushed the coolant but neither has changed thermostat radiator or water pump. I have towed truck back to my home because 2nd mechanic is charging $5000 to fix that seal he says is bad and I can't afford that. So now I'll let someone check for contamination and just change the thermostat and radiator to see if anything changes.
Old Nov 6, 2014 | 07:56 AM
unseenone's Avatar
I'm not sure about the process, but I would think, the water pump or thermostat would be the most likely culprits if there is no contamination. I would try to check contamination first.
What seal are they talking about? A leaky hose / seal should not cause overheating. A bad water pump or thermostat certainly will. The thermostat can be gotten as a complete assembly with the crossover pipe, it should be changed that way, the plastic, particularly the thermostat housing cracks (my thermostat housing cracked twice).
On other thing to note, is the fan seem to run normally, or is it roaring or doing nothing. Of course if the fan goes bad, you can also overheat.
nh9095
Jan 14, 2019 12:36 AM
thecardcloset
Jun 22, 2014 03:07 PM
turk100
Apr 9, 2012 12:59 PM
nmgirl
Dec 13, 2010 09:30 PM
Kooner
Aug 28, 2007 04:51 PM
