05 LR3 Trans Code P2718
Old Jul 14, 2019 | 04:03 PM
Abdulaleem IbnPeter's Avatar
4wd High
Default FIXED --- 05 LR3 Trans Code P2718 --- FIXED
Hi All,
I have a 4.4L LR3 that's throwing a trans code P2718. From what I've read, this seems to be a manufacturer specific code. As such, I have 2 questions:
  1. Does anyone have any recommendations where I can find a Land Rover specific code reader?
  2. Does anyone else have any familiarity with this code? I've come across a bunch of forums that talk about it but haven't really come across solutions for it.
Thanks
It ended up being a 2 prong solution
  • It had the original trans oil and filter. Drained trans fluid(though not completely) and swapped out filters.
  • One or all of the shift solenoids were all out of wack. Dare I say that I bought a used set online for cheap enough. The hard shifts into gears and between gears went away and so did tthe trans fault on the dash at least for now.
Old Jul 14, 2019 | 05:13 PM
houm_wa's Avatar
Default Only code reader you need!
https://www.gap-diagnostic.com/products/iidtool/
Pjfraser1
Jan 20, 2025 02:25 PM
GBR.R
Mar 1, 2017 03:05 PM
exhilir
Feb 14, 2014 11:16 AM
KungFooMASTA
May 6, 2011 06:31 PM
Sunny side auto
Apr 10, 2011 08:00 AM
