06 HSE LR3 water coming inside front floor mats
Old Jan 16, 2013 | 06:28 PM
Rovermike85's Avatar
8th Gear
Default 06 HSE LR3 water coming inside front floor mats
I have own my LR3 now for about 7 months and 4 days ago there was a thunderstorm that hit the town where i live, i notice that the front floor was really wet somehow water got in my vehicle, ive heard about water drainage and stuff like that where can i find these water drainage thanks..
Old Jan 19, 2013 | 02:12 PM
mx468's Avatar
Default passenger side footwell damp
Does anyone know where the ac drain pipes are located underneath the truck? I have warm water on my passenger side floor, I heard that it can be caused by ac pipe blockage. I was told to put a screwdriver up into the drain pipes to clean them out, my problem is that I can't locate them under the truck. Do I need to remove the skid plate to get access to them? Thanks. Sorry to hijack this thread. Any pics??
Old Jan 25, 2013 | 01:55 PM
mx468's Avatar
Default Found ac drains and easy access to drain
The best way to drain your ac tubes in your LR 3 is from the inside. I just went to the hardware store and got a 3ft long small cable. I placed duct tape at the end so not to snag the tube on the way down. I just fed it through from the top and out the bottom, ac tubes now cleared. You have two, one on either side of the center console. Clear both, because if one's clogged i'm sure the other is on its way. Thanks bbyer for your help.
Old Jan 25, 2013 | 04:12 PM
and a TSB for A pillar leak
File Type: pdf
Old Jan 30, 2013 | 09:13 PM
mx468's Avatar
Default Water still in passenger side foot well???
Ok I tested the sunroof drains and they drain fine, the ac drains are unclogged, I vacuumed up the water, seemed to be dry and then after driving around the floor seems damp again, no rain or snow here??? Can there be water still under the floor carpeting that I didn't vacuum up? (There is a pretty big pad under the carpet that can act like a sponge?? Possibly thawing out)The carpet also iced up when the weather was 6 degrees here.
Old Jan 31, 2013 | 02:09 AM
mroorda's Avatar
Default Water may be pooled under carpet
I had a hose pop off a connection through the firewall near the driver side leg. After I repaired it, I vacuumed the water through the carpet until it was quite dry. The next day it was soaked again. I pulled the carpet up this time and found LOTS of water pooled under the carpet. Once I vacuumed that up, problem solved.
Old Feb 4, 2013 | 01:50 PM
mx468's Avatar
Default How do you lift carpet..passenger side
I think thats the problem I have. I vacuumed up the water and it seemed dry and then a couple days later wet again. No rain, snow etc... I also did the a pillar fix, so its not that.... How did you lift up the carpet? Procedure? Thanks....
Old Feb 5, 2013 | 07:01 PM
mroorda's Avatar
Sorry, I don't remember the exact procedure, but I do remember having to remove a few pieces of trim/plastic moulding. Probably the threshold part of the door entry as well as the trim around the seat columns. I think I had to pull it back starting from the front which means you have to double the carpet back and pull from under the pedals. It's not too technical.
jlayno
Jul 20, 2018 02:13 PM
Still Lost
Apr 29, 2014 06:44 AM
NorthBoundLR3
Feb 11, 2014 09:39 PM
js80
Dec 24, 2010 06:34 PM
Hitman
May 12, 2009 11:42 PM
