2 Issues-outside mirrors & ebrake
Old Jul 10, 2020 | 01:19 PM
Island Time's Avatar
Default 2 Issues-outside mirrors & ebrake
I have a 2006 LR3 V8 with two intermittent issues:
1. The driver side mirror will work in and out no problem, but will not go up and down most of the time. Sometimes it works as designed. The passenger mirror works properly all the time.
2. The ebrake will work sometimes, but most of the time when you activate the switch it just makes a screeching sound. I turn it off right away. No lights or warning message come on.
Ideas?
Old Jul 10, 2020 | 02:56 PM
houm_wa's Avatar
The ebrake either needs to be adjusted or the actuator replaced.
Old Jul 12, 2020 | 03:46 AM
Globetrotter448's Avatar
Brakes could need adjusting. Mirror is possibly a switch connection faulty or the connector behind the door card loose.
Old Jul 13, 2020 | 12:26 AM
Thanks for the info, will check it out.
OakBehringer
Jun 16, 2019 07:58 AM
EricTyrrell
Aug 1, 2013 05:30 PM
skatelove303
Nov 11, 2009 12:18 PM
DesmondMWalsh
Sep 29, 2009 09:25 PM
Noel
Aug 4, 2008 06:09 AM
