2005 LR3 leaking coolant on front driver side
Old Oct 24, 2023 | 06:25 PM
MattEngel16's Avatar
Default 2005 LR3 leaking coolant on front driver side
Good evening fellow LR3 owners. I am new to this forum and if this is not the correct way to start a thread please let me know. Anyway, as the title suggest my LR3 is leaking coolant pretty heavily, draining almost all of the liquid I put in in one day. It is mainly puddling on the front driver's side. I am no expert and was wondering if anyone had a similar issue to give me a starting point as to what to look for. I will upload pictures when I am with my car again.
Old Oct 24, 2023 | 07:17 PM
vito13's Avatar
Default Did you worked on the car?
Did you worked on the car recently? This happened to me after removing the front bumper some how coolant started leaking front diver side. It was main hose from radiator at bottom left. Some how clamp broke and hose got loose.
Old Oct 24, 2023 | 07:30 PM
houm_wa's Avatar
Hi Matt.
The coolant expansion tank is located on that side of the engine bay, in the front. I'd look there and see if you can identify any broken hoses, fittings, etc. The thermostat is closer to the front (you'd have to remove the plastic engine cover to expose it) if you wanted to look in that area as well as the coolant bleeder and other hoses.
SCrover91
Dec 21, 2022 01:56 PM
walker139
Oct 5, 2021 04:59 PM
jfmartin25
Jan 24, 2015 10:17 PM
1961 Lincoln
Jan 13, 2011 10:35 PM
BigMike
May 19, 2005 03:13 PM
