2005 lr3 no-audio
Old May 10, 2017 | 06:49 PM
PC-06-LR3's Avatar
Default 2005 lr3 no-audio
The radio display is working-no audio.
I checked the fuses-
checked power to amp under seat-
tried hard reboot-
removed amp, opened, heating gun to soder joints-
everything is pointing to failed Harmon Kardon amp.
any other test I can do, to determine if the amp failed?
Old May 10, 2017 | 07:40 PM
EastCoast's Avatar
Did you try turning the volume **** to the right?
Sorry... couldn't resist....
Old May 10, 2017 | 08:12 PM
cmb6s's Avatar
I had the same problem a few weeks ago. Turned the car on one day and had no volume and no volume indicator when I tuned the dial. However, the rest of the functions seemed to operate normally.
First thing I did was to check the fuses. All seemed fine, so I moved on to the amp. I was getting an optical signal to the amp (red light was coming through one of the two fibre cables), so at least I knew the cables hadn't been severed. Power was also getting to the amp because I checked w/a multimeter. Couldn't tell much else, so I moved on to the Nav unit. Nav unit was getting power and was taking and ejecting the DVD okay, so I figured it was fine. Moved on to the bluetooth unit in the trunk. When I unplugged the optical cable to the Bluetooth unit, it also had a light coming through one of the cables, so I knew it was getting a signal. Checked power and put it all back together and when I did, bingo... sound! I think it had something to do with the optical cable perhaps not being seated perfectly in the bluetooth module. At any rate, the point is this:
My no audio situation was caused by a bad connection at the bluetooth module. Don't be quick to assume it's the amp just because you don't have sound. Everything has to talk properly to each other or the audio system simply won't play.
Old May 12, 2017 | 03:52 PM
DavC's Avatar
It is probably the amp. If you have no volume, another symptom is the nav screen stays stuck on the Land Rover logo.
email or pm Abran. I've gotten an amp from him before and it solved this exact issue.
Old May 13, 2017 | 08:18 AM
cmb6s's Avatar
This was true of my BT module as well. I think if there is a disconnect anywhere along the MOST fiber line, you'll get no volume and the nav screen stuck on the LR logo. Abran had an amp in stock when I was asking him a few weeks ago, so if you figure out that's what you need, then by all means contact him. Just make sure you troubleshoot first.
nh9095
Jan 14, 2019 12:36 AM
btais4595
Feb 9, 2013 06:41 PM
williamspaul
Feb 28, 2011 07:28 PM
landwarrior
Jul 7, 2006 03:28 PM
landwarrior
Audio/Visual Electronics
Dec 20, 2004 12:28 AM
