2006 Land Rover LR3 no start/no crank. Key not releasing form ignition.
Old Mar 22, 2020 | 05:40 PM
bacardidavis's Avatar
6th Gear
Default 2006 Land Rover LR3 no start/no crank. Key not releasing form ignition.
I have a 2006 Land Rover LR3 4.4. I'm experiencing a no start/ no crank. As well as key not releasing from ignition. I get these codes listed below. The battery is new. I tested the load on the battery and it doesn't change when I try to start it. I recently took the transmission out to change stator housing seal that was leaking and oil pump seal. It ran perfectly before I took the transmission out. Could it be the immobilizer? The key did not unlock the lr3 doors but still started. HELP! This thing is killing me haha
Old Mar 23, 2020 | 02:37 AM
Globetrotter448's Avatar
Points to a key problem. Have you got a second key. Have you updated anything with a tool like "Gap". Does the key turn back to 'home' position, if so rock steering wheel back and forth and it may release.
Old Mar 23, 2020 | 08:08 AM
6th Gear
Steering wheel turns freely, key will only go to 1 2 and 3. I have a new key coming in so I can program it and see if it’s key related. Also, security light is flashing
CATTIVA73
Aug 1, 2019 08:44 PM
pweinzimmer
Oct 31, 2017 12:43 PM
rickatontu
May 9, 2012 09:04 PM
bodyzoo
Dec 30, 2010 02:24 PM
