2006 - Lower control arms / Lower A-arms brand question
Old Aug 30, 2020 | 07:54 AM
pagoda's Avatar
Britpart only resells, they don't make those arms. They are made the the original OEM maker and put into a basic box with no labels, etc. Personally when it comes to bushings, the original style is best but I would not bat an eye at solids. I doubt most could even tell the difference.
mid follow this advice through and through. I wouldn’t touch poly bushes. If your lowers are gone then your uppers won’t be far behind and I’d recommend doing them together at the mileage you’ve stated. If you haven’t done them recently then do the ARB bushes at the same time. No sense fitting new arms and leaving worn ARB bushes for the pittance they cost.
ive used LRDirext Britpart parts with no problems. I didn’t know Britpart don’t make these arms though. Anyway, the LRDirect site has a load of good options and suggests which are OEM. It’s not a hard job but preparation is critical (Ie marking the camber bolts) and a good 4 wheel align afterwards.
good luck. (Do the uppers too!!!)
Kushan Gunawardane
Feb 1, 2020 05:11 PM
jft1428
Mar 22, 2018 10:25 AM
BritCars
LR4
Oct 16, 2015 02:02 PM
asv4k8
Mar 7, 2011 07:29 PM
