2006 LR3 Clutch Position Sensor Problem
Old 07-19-2022 | 12:39 AM
flyer08's Avatar
Default 2006 LR3 Clutch Position Sensor Problem
2006 LR3 121k miles Locking Rear Diff
Replaced alternator and that works fine. But I get Transmission errors on startup and dash saying traction control reduced but no red lights.
Run the Gap tool and get to faults.... Rear Diff - Clutch position sensor - circuit range performance AND Rear Diff - clutch position sensor is not learnt ,,
See pic
Next
What does that mean and what to do? Is it safe to drive?
ok, no laughing.... but what in the heck did I find in my driveway? See pics of pin and spring.
Thinking something fell off my aging car found between my LR3 and LR2. Perhaps a rear diff clutch position sensor
ok, no laughing.... but what in the heck did I find in my driveway? See pics of pin and spring. Thinking something fell off my aging car found between my LR3 and LR2. Perhaps a rear diff clutch position sensor
Old 07-19-2022 | 07:23 AM
DakotaTravler's Avatar
It means your rear locking diff needs a software update and likely a new locking actuator assembly. You can drive it, but its possible that the clutches in the rear diff are engaged and thus could wear out fast under regular driving conditions. Or they are not stuck in an engaged position and you are fine. Either way, its generally means you need to repair it.
Old 10-01-2022 | 07:36 AM
Saurav005's Avatar
5th Gear
Default Need Help
Hi I need help for the same problem. The mechanic opened the sensor instead of oil drain plug. Now my rear diff is not working and giving same problem with transmission fault and traction reduced.
How to resolve this. Even i couldn't find that spring part in the sensor which he took out.
I showed it to the other mechanic he says he will open the diff ....Help me out guys what should I do....
Opened this sensor insted of drain plug
Information in dash board
See pic
Next
p
Old 10-02-2022 | 07:19 PM
Your mechanic should fix it, he messed it up.
Old 10-02-2022 | 09:26 PM
flyer08's Avatar
Dakota is correct.... He should fix it.
My part was the hex shaped 'plunger' that somehow came off. I think this is specific to a locking rear diff but not sure. Dakota posted a great cut-away of a locking diff.
fyi, I replaced my diff... Thinking you situation is a bit different. Let us know
Old 10-02-2022 | 09:29 PM
flyer08's Avatar
Do you have an E locking rear diff?
Saurav005 (10-03-2022)
Old 10-02-2022 | 09:36 PM
flyer08's Avatar
Old 10-02-2022 | 09:37 PM
flyer08's Avatar
Old 10-02-2022 | 09:38 PM
flyer08's Avatar
Thank Dakota for those pics
Old 10-03-2022 | 12:49 AM
Saurav005's Avatar
5th Gear
Yes it's E Locking diff.
They will open the diff today to rectify it. Fingers crossed.
Quick Reply: 2006 LR3 Clutch Position Sensor Problem
