2006 LR3 Front driver caliper stuck
Old Sep 27, 2019 | 11:37 PM
Gina's Avatar
Cool 2006 LR3 Front driver caliper stuck
Hello,
I have a 2006 LR3 with 184K miles.
In 06/18 I had front brakes rebuilt (pads,calipers & rotors) by a reputable brake shop. No problem until yesterday when front driver caliper stuck. My husband is going to do this rebuild himself.
Question: Where’s the best place to order brake parts for my LR3? I usually order from AB but wondering if anyone else could recommend a less expensive option. I also am going to change out the hose.
Thanks to all,
Gina
Old Sep 28, 2019 | 11:55 AM
I order mine from Lucky8 but I am a bit biased lol.
Keep in mind the caliper could be fine and it's simply a stuck guide pin. You can sometimes pop them loose clean and lube.
Check to see if it's a froze guide pin before you order. If you need the bracket and pins it will slow you down a bit having to wait for more parts
Cjlr3
Mar 18, 2019 09:35 AM
Frank4
Sep 2, 2014 09:25 PM
zahnieblack
May 12, 2011 01:36 PM
Big_Easy
Jun 24, 2009 01:15 PM
matthiasg
Dec 28, 2008 08:37 AM
