2006 LR3 HDC Transmission fault - F error
Old Apr 9, 2017 | 11:18 PM
mrhollaway's Avatar
Default 2006 LR3 HDC Transmission fault - F error
i have 2006 LR3 and i get this transmission fault. Ive read up on forums and also tried the emergency brake release and that worked a couple of times but now when i start car and try to go forward or backward i get the error and car wont move. it seem like maybe its the transmission but possibly the emergency brake. i see others with this issue and no one seem to know exactly the issue. any help is appreciated in advanced
Old Mar 30, 2021 | 05:02 PM
Elienay Granitos's Avatar
3rd Gear
friends would like to reciprocate ... with a big tip ... failure in the socket of the brake lights (lack of ground contact) means that with the half light on the car does not change gears ... in addition to generating numerous failures. .. when it happens when you turn on the headlights to hear the gear change ..... we hear the same noise when you step on the brake. thankful.
ElCid12
Feb 7, 2021 04:45 PM
charleswestwood
Dec 24, 2020 04:41 PM
VinJones
Jul 25, 2020 06:49 PM
Cookiemonster
Feb 25, 2015 08:04 AM
