2006 LR3 issue HDC
Old Jan 3, 2016 | 05:24 PM
Ckm983's Avatar
Default 2006 LR3 issue HDC
I park my vehicle in my driveway on a slight upward angle. When I put the vehicle in reverse it activates the HDC fault and lowers the suspension and turns off the special programs. When the vehicle is parked on a level area no issue.. Any idea why this is happening, the vehicle is parked front up in the air slightly...
Old Jan 3, 2016 | 09:17 PM
houm_wa's Avatar
Typical issues causing these symptoms: battery, brake switch, brake lights, wheel angle sensor.
Old Jan 4, 2016 | 03:32 AM
DavC's Avatar
IF you have an IID tool run codes, maybe try calibrating suspension. In VERY cold weather I have gotten HDC fault and no special programs, but this was only in below freezing. Goes away on restart.
Couldn't hurt to ask a dealer about it. If they're nice they could diagnose.
Old Jan 6, 2016 | 02:09 PM
KMET's Avatar
Could also be water intrusion, front/back passenger side. Been raining a lot?
Old Jan 6, 2016 | 05:48 PM
Ckm983's Avatar
Yes, how could/would that effect it?
Old Jan 6, 2016 | 07:15 PM
KMET's Avatar
Main wiring trunk runs under the passenger-side carpet, front to back. Once water
accumulates more, you'll have random starting issues, EAS failure and possibly blown fuses.
Channels themself are about 2 inches deep (Same as drivers side) they can hold a good amount of water. Sunroof drains (Drivers/Passenger) & front pillars are incursion points.
aircraftguy
Feb 19, 2022 08:22 AM
Bamarover2
Jan 10, 2016 04:36 PM
Bean
Jul 15, 2010 11:13 AM
