2006 LR3 Locking Rear Diff with Huge Leak
Old Jul 20, 2022 | 09:08 PM
DakotaTravler's Avatar
In the pics, there appears to be a black o-ring/seal - it should not exist there.
Old Jul 20, 2022 | 09:11 PM
Originally Posted by flyer08
Would it throw a rear diff clutch sensor code if low on fluid?
Well yeah, cause the diff clutches would be toast and more then likely the gears would be damaged. Really depends on how low it got. When you drain it, because you must, you should measure how much comes out. What goes in will be about 1.5 quarts or so. Either way, you need two quarts of proper carbon clutch compatible fluid - or again, the clutch pack will burn up. Rover sells the fluid or you can get GM equivalent 92184900, which is used on GTOs with carbon clutches, but the GM fluid is cheaper and usually easier to find at Napa and such.
Old Jul 20, 2022 | 09:13 PM
flyer08's Avatar
That black o-ring looked copper in the light
And your right on drain and fill plug
Old Jul 20, 2022 | 09:14 PM
Well either way, that o-ring should not exist. The only thing I do with drain/fill plugs on the diff is put some teflon tape on them - the same tape used for pluming. Dirt cheap and helps prevent leaks.
Old Jul 20, 2022 | 09:15 PM
flyer08's Avatar
Orlando Land Rover is $103 for plug and 2 quarts
Old Jul 20, 2022 | 09:18 PM
The plug is like a $5 part. The fluid maybe $60 for two quarts if you go GM. You can also try to find Castrol BOT 720 - rare stuff, very good, no longer made. I suggest calling your local Napa, etc. The big chains don't usually carry the GM stuff. Its a bit of a specialty item. If you find Castrol, it will be old stock which is fine but you might get a good deal if someone wants it gone.
edit:
Amazon Amazon
Old Jul 20, 2022 | 09:21 PM
flyer08's Avatar
I love my old LR3... but among smaller things, have a strong feeling rear locking diff needs a rebuild plus E motor... followed by front diff rebuild
What would be a fair price for parts (rebuilt) and labor on:
Rear locking diff
Front diff
Would you go rebuild or chance used?
Old Jul 20, 2022 | 09:24 PM
Someone else will have to answer that cause I do all my own work. So no clue on paying someone to do it. But parts along run into the hundreds. I think a front diff along can be about $2-$300 in parts.
Old Jul 20, 2022 | 09:26 PM
flyer08's Avatar
can I ship you a project? LOL
Old Jul 20, 2022 | 09:27 PM
I barely have time to fix my own! LOL
