2006 LR3 Manifold leak?
Old Apr 25, 2021 | 11:29 PM
flyer08's Avatar
Default 2006 LR3 Manifold leak?
2006 LR3 103k miles, Manifold leak? This a minor sound I can hear when engine is just started and cold. A soft puff of sound, no smoke or oil leaks. Nearly completely gone when at normal temp. Bothers the heck of of me thinking it may get worse. Possible a head or manifold bolt has stretched and lost torque?
Last, only when cold, Florida cold, sometimes I can also hear a squeak... Only hear similar on other make cars for belt or going bad water pump. Any ideas?
Old Apr 28, 2021 | 04:14 PM
cybercop's Avatar
Wouldn't you get a lean P171 or P174 depending on the side since extra O2 is introduced before the O2 sensors.
Old Apr 28, 2021 | 09:20 PM
flyer08's Avatar
Great point!!!! I had that code about 3mo ago and just got a check engine light..... bet you called it. Heck, Ill check now. Let you know. Thanks
Old Apr 28, 2021 | 09:51 PM
flyer08's Avatar
Although have GAP with VIN for LR3, used my old OBII scanner to read then clear
2006 LR3
codes
PO 172 System to rich bank 1
PO 175 System to rich bank 2
I cleared and all ok. Well sorta.... guess is stressed and stretch manifold bolt(s). Similar happened to Shelby during a race the first year of the GT40
Think diagnose correct?
Fix 1 Pull off and torque new bolts w/ new gasket
Fix 2 Pull one bolt at a time and replace new to correct torque
Old Apr 28, 2021 | 09:58 PM
flyer08's Avatar
First time bake 1 and 2.... thats both sides I think
had code through bank 1 3to6 months ago
Old Apr 28, 2021 | 10:02 PM
flyer08's Avatar
Hey, see some from Lucky8
Just bought GAP and more there.... Great customer service. Recommend buy there
Old Apr 29, 2021 | 09:04 PM
flyer08's Avatar
Used GAP today for first time on LR3. Showed codes again bank 1 and 2 running rich... Will need to run the easy stuff first, but I think that slight 'wisp' sound when first start cold and there till at normal running temp is related
Old May 25, 2024 | 06:40 AM
vito13's Avatar
Originally Posted by flyer08
Used GAP today for first time on LR3. Showed codes again bank 1 and 2 running rich... Will need to run the easy stuff first, but I think that slight 'wisp' sound when first start cold ad there till at normal running temp is related
Did you ever find out what the puff sound was? I have the exactly same problem
vanbadri
Jul 31, 2019 09:19 AM
djkronik57
Sep 20, 2016 07:17 AM
LR03NJ
Feb 20, 2016 02:46 PM
4x4ron
Sep 3, 2012 09:57 PM
mcolgan
Mar 27, 2011 03:56 PM
