2006 LR3 missing heated windshield relay
Old May 25, 2024 | 09:48 PM
CarGuyNye's Avatar
Default 2006 LR3 missing heated windshield relay
Hi everyone,
so I was recently working on my 2006 LR3 with about 176k miles, and was checking the fuse box under the hood. I noticed one of the relays was missing, it seems one of the larger ones for the heated windscreen. I’ve done some part searches at various sites but nothing comes up. Could someone please tell me what the part number is for that relay? I noticed last winter that the windscreen was not clearing when it was iced up; I think I may have found the problem.
Thank you!
Old May 28, 2024 | 07:50 PM
DakotaTravler's Avatar
Just a standard relay. There are two fuses though, one for each side. And are you certain you have a heated windshield? Usually a standard option on NA model, but I have seen builds without them. Also there is the chance the heated was damaged and replaced with a non-heated.
Old May 28, 2024 | 10:00 PM
CarGuyNye's Avatar
Hi, yes, it definitely has the heated windshield option as you can see the squiggly lines in the glass and it has the corresponding switch on the dash. I actually just ordered a 4 pin, 40 amp relay to see if that will fix the issue. I don’t know why someone would have removed that relay though. The fuses were still there though, but I also noticed there was a fuse missing for the air suspension.
Here is a pic of the fuse panel showing the missing relay and the fuse.
MaineLR3
Sep 7, 2023 06:45 PM
grandkodiak
Apr 8, 2013 05:31 PM
Flyin2jz
Nov 12, 2012 10:52 PM
hpipe
Dec 12, 2008 09:06 AM
wimp
Oct 28, 2006 05:17 PM
