2006 LR3 no apark
Hi everyone is nice to join this forum and hopefully someone can help me out on this vehicle. The LR3 had this Ramdom problem happening for a long time but just for a short time Sometimes the car will crank and crank and after few key cycle the vehicle start. No after changing the main seal battery off for 2 days doesn't start at all . There’s few videos on YouTube from this guy that disconnect the coil 1 and car start well in my case non of that help. My car will crank but the coils will only spark once at initial crank and the engine detonated a bit. I have checked timing , replaced plugs, ignition switch, cam sensor , crank sensor , CAPACITOR in the engine bay , I have fuel and I can’t figure this problem out. No faults at all register in the ecu and also while cranking the rpm needle doesn’t move at all. Please help and thank you in advance.
I haven’t check fuel pressure since my plugs are coming out wet on gas and the injectors are floating the cylinders with unburned fuel. I have everything but spark and only one spark on first crank and after engine is cranking the spark goes away :-(
