2006 lr3 p0308 ,p0316 , p2401 , p0447
Old Dec 15, 2020 | 11:22 AM
Keiths5n10's Avatar
8th Gear
Default 2006 lr3 p0308 ,p0316 , p2401 , p0447
HAVEN'T OWNED THIS VERY LONG, & RUNNING REG. FUEL, ENGINE LIGHT WAS ON STILL RAN FINE! OTHER MORNING TOOK OFF WITHOUT WARMING UP, STARTED RUNNING ROUGH . HOOKED UP SCAN TOOL & WENT FROM P0308 TO
P0308
P0316
P2401
P0447
GUESS i'LL START WITH PLUGS , COIL PACK IF i CAN FIND ONE EASY ENOUGH, PUT SOME BERRYMAN FUEL SYSTEM CLEANER IN TANK , ANY HELP VERY MUCH APPRECIATED , THANKS KEITH B
Old Dec 15, 2020 | 12:24 PM
houm_wa's Avatar
V6 or V8? If the latter, try running premium, too.
Old Dec 15, 2020 | 12:44 PM
Keiths5n10's Avatar
8th Gear
4.4 V-8 , parts house has nothing I want, so.. Amazon it is
Any suggestions on SPARK PLUG CHOICE, last time I changed plugs on my Ford Truck BOSCH LET ME DOWN.
Leaning towards NKG
Old Dec 15, 2020 | 02:47 PM
DakotaTravler's Avatar
There are no coil packs on the 4.4 V8.
Always run premium.
Old Dec 16, 2020 | 10:01 AM
douglastic's Avatar
Leaning towards NKG
OEM Spark Plugs: NGK IFR5N10 (LR005253)
Old Dec 16, 2020 | 10:11 AM
I installed the new NGK 95839 {#FR5AHX} Ruthenium HX plugs. I am not a fan of BOSCH plugs either, in fact its amazing how many car forum users have issues with BOSCH plugs or O2 sensors.
Old Dec 18, 2020 | 07:25 PM
Globetrotter448's Avatar
Using Upper case letter is like shouting at people. I would go with the plugs (Autolite) from Ford as it is one of their engines
Old Dec 25, 2020 | 05:19 PM
Keiths5n10's Avatar
8th Gear
Default Cylinder 8 misfire code
Leaning towards NKG
Senior member posted my engine didn't have coil on plugs!? Well seems so, I was pretty sure but being a newbie. After Xmas stuff decided to get under the hood! Plugs showed up 24th.. my Xmas!
Old Dec 28, 2020 | 04:38 PM
Thats a COP (coil on plug), not a coil pack..... Like I said, these trucks dont have coil packs...
Old Mar 8, 2021 | 09:23 AM
Keiths5n10's Avatar
8th Gear
Default 2006 lr3 still throwing codes
This all started one morning , cold start. lack of power, stumbling, engine performance light & various codes . After initial Plug Replacement, not much change. Removed & cleaned MAF & cleaned Throttle body , ran out good for a spell .. then back to rough running & if I peddle it up, diminished engine performance lights up. Think I'll replace MAF, Thoughts on MAP? Plugs looked as if they were ready for replacement (not as bad as I thought. R&R) . Reading about CMP possibly causing problems but don't feel like spending money throwing darts! Going to clean MAF again check codes & run it, while ordering/ shopping for one. Thoughts on aftermarket MAF?
bhmav8r
Dec 15, 2025 08:04 PM
JayButler
Apr 21, 2020 10:09 PM
TabSea
Jan 14, 2019 12:33 AM
mpothen
Mar 23, 2016 08:42 AM
ghtaylor
Feb 15, 2016 06:01 AM
