2006 LR3 Where is the starter?
Old 07-29-2013, 12:46 AM
Skyelr3's Avatar
Unhappy 2006 LR3 Where is the starter?
2006 LR3
Where is the starter? Need to check and remove but can't even find it.
Does anyone have images if their removal and reinstall?
Thanks.
Old 07-29-2013, 12:54 AM
Pages from the shop manual. You can download the whole thing for free in my signature links. Looks like there is more to it than in the older trucks.
File Type: pdf
File Type: pdf
File Type: pdf
Old 07-29-2013, 01:06 AM
Skyelr3's Avatar
Thanks !!!
Old 07-29-2013, 01:16 AM
I hope you are not planning on doing this at 2:00AM.....
Old 07-31-2013, 10:40 AM
ktm_525's Avatar
If you need to replace the starter it can be done without disconnecting the ball joints. The starter is located on the passenger side of the vehicle. What I did was jack up left side of vehicle and place a 6 ton jackstand under the frame near the front. Remove front passenger wheel and the disc brake rotor covers. I am unsure if I removed the rotor/caliper itself. Then with the front hub hanging free place a jack under it and slightly compress the suspension. This will allow you access to remove the wiring harness and the two bolts to the starter. Be aware that you are placing your arm in a lightly loaded suspension. It could get pinched if the jack failed. Using this work around I was able to replace the starter in under an hour. A surprisingly easy job.
Old 07-31-2013, 11:17 AM
Safety first, extra supports to keep the compressed parts from escaping and your name changing to "Stubby". Read Murphy's Law, section 235.67 (a) - the mindless machine has no mercy...
Old 07-31-2013, 02:25 PM
ktm_525's Avatar
Good point. I forgot to add that I had a smaller 2.5T jackstand on the control arm in case my jack moved. Also disconnect battery so the rig doesn't decide to self level with your arms in there..
Old 07-31-2013, 08:42 PM
Skyelr3's Avatar
Good one.
Thanks for all your input savannah buzz and ktm_525! Have yet to attempt.
Old 10-07-2013, 06:32 PM
Skyelr3's Avatar
the culprit was the transmission fuse. any idea how that could blow?
Old 10-07-2013, 07:13 PM
roverguy7's Avatar
What fuse number?
Gimebakmybulits
07-14-2014 05:57 PM
johnkbl
04-23-2012 07:49 PM
Bean
07-15-2010 11:13 AM
rpupunu
10-15-2009 01:58 AM
MagnaflowRep
Headers, Intake, & Exhaust
09-02-2009 12:26 PM
Quick Reply: 2006 LR3 Where is the starter?
