2007 LR3 AC question Help
Old Oct 15, 2015 | 11:21 AM
LR3BB's Avatar
5th Gear
Default 2007 LR3 AC question Help
I posted a few weeks ago my AC was hit and miss. At that time, I got a DIY Recharge kit. I filled the Low Side with refrigerant. When i hit the trigger on the recharge can, the pressue would go into the red on the guage but when I let off it would slowly wind down a little. I did this until when I let off the trigger of the recharge kit, the pressure would go from Red- to into the green.
At this time my AC started blowing cold again! Yay..
Then... My ac would start working, then go off, then back on while driving. It stopped working really at all. I checked the pressure on the low side again, and it said it was in the Red now, 90 PSI or so. I didn't know what do to, so I let a little pressure out of the unit until the PSI was back into the green. AC still blows hot.
What do I do now? Add Refrigerant and see if it starts working? Replace compressor? Take it to AC shop?
Old Oct 15, 2015 | 11:34 AM
jafir's Avatar
To troubleshoot correctly you need to be able to monitor pressures on both sides.
If the compressor was not running, then the suction (low side) pressures go up. So if you let some out, you may now be undercharged. But without being able to see the high side pressures, it's hard to tell what's really going on, such as expansion valve operation, etc.
Old Oct 15, 2015 | 12:58 PM
Airstream345's Avatar
What Jafir said....
I'd recommend taking it to a shop. They can diagnose it pretty quickly with the proper gauges, etc. FWIW - Sounds like a low refrigerant level or possible leak issue.
Old Oct 15, 2015 | 03:05 PM
LR3BB's Avatar
5th Gear
Weird thing, I was on they way to get some more refrigerant and the AC started working again. Who knows for how long.
Old Oct 16, 2015 | 06:19 AM
drowssap's Avatar
if you could fit a whole can of refrigerate into your system, you have an issue.
it should be addressed by someone with the proper tools, ie. gauges and a vacuum pump.
nh9095
Jan 14, 2019 12:36 AM
hkaraaslan
Sep 6, 2009 01:19 PM
sdrovn
Dec 21, 2007 10:38 AM
dunk0963
Aug 22, 2007 02:17 PM
Paul LR3
Jul 18, 2007 02:39 PM
