2008 LR - Roverland Engine being installed in July - What else while it's out?
Old Jun 29, 2020 | 02:27 PM
drew888's Avatar
Default 2008 LR - Roverland Engine being installed in July - What else while it's out?
My 08 is in great shape otherwise so I'm keeping it. I'm hoping the guru's here can help with putting this together right. Meaning, I just read about the PCV so of course I'll install new but what else? Does the 4.4 have the coolant crossover tubes the 5.0 has? I could use a hand in replacing all that make this as reliable as it can be. I know that Gerry at OCRovers knows what he's doing but I'd like a list to go over with him to not miss anything.
  • PCV
  • Water Pump
Many Thanks,
Drew
Old Jun 29, 2020 | 05:20 PM
DakotaTravler's Avatar
The rear main seal. Not a common issue but anything between the engine and trans that could fail should be replaced. And the rear seal is not stupid expensive (I think).
The 4.4 does have a crossover tube. Its actually part of the t-stat housing. Its a known weak point, the plastic cracks. Go OEM only, the aftermarkets seem to crack early.
Really teh PCV and water pump are so easy to do with engine in place, I would not consider them a priority. But if you are doing those anyway, I would replace all pulleys, the idlers, tensioners, etc. Basically any belt component that is not an accessory. Again not expensive, but those things wear.
Old Jun 29, 2020 | 05:54 PM
drew888's Avatar
Thank you sir!
VPS2509
Dec 5, 2016 02:28 PM
Johnny42
Feb 28, 2009 09:37 AM
PaulAd
Dec 2, 2008 03:07 AM
Markos111
Nov 25, 2008 01:58 AM
TWSTRCHASR
Sep 12, 2007 03:59 PM
