Tcase leaking
Old Jun 19, 2020 | 08:37 AM
Skyjacker03's Avatar
Default Tcase leaking
Hi-
I noticed a few drips of oil in the driveway. So I decided to look at it while I had the skid plates off to change the oil. The skid plates are dry. It looks like the oil is coming from where the case splits. Is this a common lead area? I wasn’t sure if it is coming from somewhere else and running there. Did anyone pull the transfer case on one of these? Curious how hard/time it takes to remove.
Thanks,
Joe
Old Jun 19, 2020 | 09:56 PM
DakotaTravler's Avatar
This PDF may help a little.
File Type: pdf
Old Jun 21, 2020 | 01:19 PM
Thanks! I thought I read that some where that you needed to take the exhaust down. That’s not to bad.
how hard is it to split the case? Looks like that’s where it’s leaking from.
Thanks again,
Joe
Old Jun 21, 2020 | 07:37 PM
No clue on splitting, I have not done so yet. Before you dive into this, I would clean everything really well and verify the leak location. Liquids like to move about, especially hot liquids. You just want to be sure its not the trans output seal, etc. If it really is the transfer case, you can always pick one up for fairly cheap. I see them go for less than $300, some less than $200. Then you can bench rebuild and take your time. Then you just have to swap em. Unless the downtime of the truck does not matter.
Old Jun 21, 2020 | 08:15 PM
I guess I could do that. I find it hard to believe the case is leaking between the two 1/2’s but maybe? It’s only got 79k miles on it. That’s where it looks like it is. I’ll have to investigate more.
Thanks,
Joe
Old Jun 22, 2020 | 07:14 AM
Blackngold77's Avatar
Thanks,
Joe
I'd check the threads on the drain hole too.
Aluminum case and steel plug with no steel insert means the threads can VERY easily get stripped out if it was overtightened. Once they strip the plug may stay in place but fluid will seep out from it
Old Jun 22, 2020 | 06:53 PM
Thanks, I’ll check that out also.
Thanks,
Joe
Old Jun 29, 2020 | 07:59 PM
Also maybe of use, for reference.
https://www.rangerovers.net/threads/...eardown.41233/
Colorado David
Sep 1, 2014 01:44 PM
blackpaw80
Jul 12, 2013 11:22 AM
04DiscoverySE
Oct 17, 2012 10:41 AM
mrrepairman
Aug 29, 2009 07:19 PM
Chrisinhouston
Aug 17, 2009 11:51 AM
