Old Aug 9, 2015 | 03:27 PM
alvin18's Avatar
8th Gear
Default 265-60-18
This size tires came with the vehicle when I bought it, looks good and fills the wheel well nicely. I am in the process of finding a matching spare. Has anyone fit this tire size on a full size spare and it fits in place?
Old Aug 9, 2015 | 06:36 PM
thorgal's Avatar
Fits just fine in the designated spot.
Old Aug 11, 2015 | 06:13 AM
Ghaniba's Avatar
Yep, it was an option from factory - the HD option that also gave a rear locker.
Dave
Old Aug 12, 2015 | 08:45 AM
mx468's Avatar
Just got a spare the other day this exact size. Fits perfectly in the spare location under truck.
Old Aug 13, 2015 | 02:04 AM
alvin18's Avatar
8th Gear
Thanks for the reply, I am still waiting for the wheel, but happy to know it will fit!
Old Aug 14, 2015 | 03:25 PM
uoflcardfan77's Avatar
Quick question. The 265/60/18 tire size will fit without any rubbing, even without a lift kit correct?
Old Aug 14, 2015 | 05:38 PM
thorgal's Avatar
No need for a lift .Fits just fine with no rubbing at all.
Old Aug 14, 2015 | 06:43 PM
Good. I'm getting close to needing new tires and I noticed how many more options there are with the 265's vs. the 255's that are on it now.
Old Aug 14, 2015 | 06:52 PM
abran's Avatar
I have looked but haven't found the answer.
What is the biggest 18" tire that will fit in the spare location?
What is the biggest 18" tire you can use with a 2.5" Johnson or proud rhino lift without ANY rubbing?
Thanks
Old Aug 14, 2015 | 08:58 PM
houm_wa's Avatar
Probably 265/65 for both questions.
I am not sure. I run 275/65s. I put the spare in the boot and once in a while when really articulated...I rub. Plus I no longer run a rod-based lift; I use the IIDTool.
