270 Awning recommendations for LR3
Old Mar 31, 2021 | 11:31 AM
jbullock78's Avatar
Default 270 Awning recommendations for LR3
Hello-
I am looking for recommendations for a 270 awnings for my LR3- I am leaning towards the compact Rhino Rack batwing, but was concerned about the rear hatch causing an issue with the awning.
Does anyone have any experiences with it?
Thanks,
James
Old Mar 31, 2021 | 07:28 PM
loanrangie's Avatar
Which ever one you fit you need to mount it high enough so it clears the hatch, i find a standard side awning works fine with the tailgate up.
Old Apr 1, 2021 | 06:39 AM
jbullock78's Avatar
Thanks!
Old Apr 30, 2021 | 08:34 AM
Rufflyer's Avatar
Default AluCab 270
AluCab with Front runner brand mounting hardware. Slight interference with tailgate up, but nothing I can't live with. I could have mounted it higher, but then it would not fit in my garage (even in access height)
As a side note the heat barrier material on the bottom side of the awning does an incredible job reflecting the heat from the south Texas sun.
Look at the features of each awning. Pick the one you like and mount it high enough to miss the tail gate. They all will interfere when mounted low.
Just my 2 cents worth.
Jeff
d
jfmartin25
Jan 24, 2015 10:17 PM
TRIARII
Oct 18, 2013 12:10 AM
1961 Lincoln
Jan 13, 2011 10:35 PM
gvmnt
Aug 7, 2007 05:37 PM
trini defender
Jan 11, 2007 06:34 PM
