33s on an LR3? Yes, but...
Old Dec 1, 2015 | 11:07 AM
  #21
houm_wa's Avatar
I agree and have read/heard everything you just stated about the STT Pros and the D-Tracs and Fierce tires. I'd love to hear how the Pros perform on your LR3. As we all know tire performance can vary from fitment to fitment.
I have 2 more years with my MT/Rs though...at least. They were made in 2007 I believe (probably late '07 as I bought them in early '09). 10 years is the guidelline....
Old Dec 12, 2015 | 07:55 PM
  #22
spiderman's Avatar
I'll chime in on this after I test fit these.
I have many posts on here regarding the 285/65 R18 NITTO Trail Grapplers I have mounted on OEM wheels, which are ridiculously wide, causing rubbing on the upper A arm at Normal Height and even worse rubbing at Off Road Height or under compression. I currently require 3/16 inch spacers just to get by. These spacers remove the need for longer studs or expensive spacer kits, but are not ideal.
The new American Racing AR893 wheels have a back spacing difference of nearly an inch, so spacers will be a moot point, but this will change the swing radius just the same.
The 285's measure out at 32.59 with a width of 11.22 inches (285mm, of course). As a result I expect A LOT of clearance issues. I am most likely going to have to sacrifice the width and the look of the aggressive sidewall (and possibly some of the height) in order to gain back the clearance for the new swing radius.
With all that said... I still end up with a wider stance due to the gain in back spacing, even if I lose the width of the tire tread.
The last photo is the previous summer set up. I only had one set of four wheels. Now with my spare OEM and five new ARs, the winter tires are now on the OEM wheels and the Grapplers are on the new ARs. I have 5 of each wheel and so if all else fails I can run the Grapplers as spares once I buy new rubber for the ARs in the spring. Hopefully the size difference will not be so far off to cause differential troubles, but if so the Grapplers could be sold to recoup some of the cost of six new tires.
Fingers crossed
Attached Thumbnails 33s on an LR3?  Yes, but...-screenshot-2015-10-23-8.50.52-pm.png   33s on an LR3?  Yes, but...-12299185_10156288233980383_2845735752432450454_n.jpg   33s on an LR3?  Yes, but...-1403514_10153554397035383_1992556324_o.jpg
Old Dec 13, 2015 | 09:08 PM
  #23
Tratcliffe's Avatar
"And yes, I'm just trying to get a little more clearance. Is it worth it? Honestly, probably not for most people. I would hesitate to recommend it. I usually recommend a 265/65-18 for most people as it's the safest fitment"
So the 265/65/18 will fit the LR3 with NO rubbing issues? No need to re-route any wires? I was thinking 265/60/18 but would like the 265/65/18 if no problems for stock LR3.
Thanks
Old Dec 13, 2015 | 09:30 PM
  #24
spiderman's Avatar
I will refer you to this chart from Johnson Rods
LR3 Tire Size Chart
the 65s are just over an inch bigger than the 60s. If you are looking for a tire with no lift, you may have to settle for 265/60 R18
Old Dec 15, 2015 | 11:53 AM
  #25
Ghaniba's Avatar
Louder and don't really fit you say?
Sawzall.
Dave aka Ghan
Old Dec 15, 2015 | 01:53 PM
  #26
houm_wa's Avatar
Those look really sweet!
Old Dec 15, 2015 | 03:31 PM
  #27
DavC's Avatar
LR3 Tire Size Chart
Can confirm on the 60 size. Wishing I went with 65, but I have ZERO rubbing issues except for minor "kissing" of the frame horns which have since been ground down/cut. If I had to choose I'd go with the 65 though.
Old Dec 15, 2015 | 09:19 PM
  #28
Zelatore's Avatar
I just realized I never posted an over-all pic of the truck. This is it at off-road height w/Johnson Rods installed and 275/70-18 Cooper STT-Pros (33.3") on stock wheels w/no spacers.
Old Dec 16, 2015 | 04:31 AM
  #29
Tratcliffe's Avatar
Default Nice, what brand? Did y install, any issues with install?
Sawzall.
Dave aka Ghan
Nice, what brand? Did you install, any issues with install?
Old Dec 16, 2015 | 07:54 AM
  #30
Ghaniba's Avatar
They are Nitto Mud Grapplers, 33x12.5 on the stock rims. I'll try not to drag this thread too much off course, I've got a good writeup for my truck here:
https://landroverforums.com/forum/lr...g-woods-73607/
Dave aka Ghan
