After Market Radio
Old Dec 11, 2022 | 09:41 PM
Mango2022's Avatar
Default After Market Radio
Hello LR owners, I have a question hopefully I can get an answer. I am replacing my navigation unit with a 10.1 multimedia radio. I bought the Axxess radio harness for the LR3 and connected the plugs to each other as directed. I can not for the life of me get any sound. My friend and I determined that the amp is blinking yellow when there is no sound. I connected everything back to see the status of the amp and it stays a solid yellow light. Can anyone give any advise on what am I doing wrong. Thank you in advance.
Old Dec 12, 2022 | 05:58 PM
DakotaTravler's Avatar
The factory amp has a yellow light? Never noticed I guess. Does the new unit you are putting in connect to the MOST network? If not did you bypass it?
Old Dec 12, 2022 | 07:08 PM
Mango2022's Avatar
Default Radio connect LR3
what is the Most Network? I have the Harmon Kardon unit with amp. How do you bypass ?
Old Dec 12, 2022 | 07:23 PM
The MOST network is the fiber network. I assume what you are putting in is compatible with the truck, so the MOST network should be needed to connect. Two orange covered fiber optic cables make up the network ring. If it does not use it, it has to be bypassed. Although if the thing you are installing does not use MOST, then not sure how it will work anyway without some sorta interface. The factory AMP is the brain and audio system for the truck. The head unit in the dash is pretty much a dummy.
Old Dec 13, 2022 | 04:50 AM
Mango2022's Avatar
Default After market rasio
Yes I do have the MOST system and have the orange fiber optic cable. I agree that if the amp doesn’t work the radio is a brick. Do you have a pic for how this should be connected?
Old Dec 13, 2022 | 07:21 AM
The connector just goes into what you are installing. Or you pick up a MOST bypass on eBay and attach, which will complete the loop that was broken by removing the Nav unit. Keep in mind the unit you are installing will never work with the audio system though.
Old Dec 13, 2022 | 09:16 AM
Mango2022's Avatar
Thank you . After watching so many videos , I finally found one that mentions the optical loop bypass connector. Without thst , there is no sound! And that’s exactly what happened to me. I ordered this part and once I get and connected, I will give you the update. Thanks a million for your invaluable feedback.
This is what I bought
Old Dec 13, 2022 | 01:31 PM
Mango2022's Avatar
Another question, so now that I am replacing the original Navigation, I do not need the navigation connections, correct?
Old Dec 13, 2022 | 04:47 PM
If you are only replacing the navigation with something independent, then no, you won't be using any of the connectors. I assume what you are installing is, essentially, just a tablet with its own data/GPS, etc?
mihaipg
LR4
Dec 10, 2020 01:53 AM
EastCoast
Jun 21, 2017 04:03 PM
jeepguywithadisco
Jan 1, 2015 07:53 AM
Rodsram
Aug 19, 2013 05:38 PM
bweaver
May 6, 2007 09:47 PM
