Aftermarket stereo and backup camera on my 06 LR3
Not totally sure, but I think the basic radio does not use fibre optic cables. When I did mine I used the EONON double din radio (Android based) from eBay and it came with all bits, connectors and cables, had to buy the Ariel kit though to join the original to the kit supplied one. Reversing camera was one purchased from eBay and fits into the number plate light fitting. Running the cables for reversing camera was interesting
Codyhood (03-23-2020)
My double din is from wish so i dont know exactly what brand it is however i wasn't able to install the system because i bought the wrong dash instalation kit. Im going to try and find set of connectors for the stock wiring so i dont haft to hardwire it in .does anyone have a pacific place they buy aftermarket wiring harnesses from?
You will need the adapter harness that includes the fibre optic (MOST) cable, most Asian origin head units come with ISO plugs as standard so in most cases just the one harness is required.
If you have sat nav then it may or may not work depending on the harness kit you get, in the UK you would get a kit by Connects2 and in Australia i used the fitting kit by Aerpro .
