air suspension leak! help please!
Old Feb 21, 2018 | 04:35 AM
Enlund27's Avatar
Default air suspension leak! help please!
HELLO
06 disco that drops in the front and get fault code c1a13
all the airsprings changed by previous owner in september.
the compressor is amk and changed by previous owner 1 year ago.
i have changed front valve block in november.
disconected the front valve block incoming air line last weekend and noticed on my nanocom that the gallery pressure is 97 but all the air has escaped! faulty sensor?
disconected fuse 26 the result was front right down to bump stops after 12 hours and the left down by one inch!
tryed soupy vater. listening everything cant find any leaks.
the suspension pumps up nicely when starting car and gallery pressure about 260. after 40 minutes driving ill get suspension light to come on and the gallery pressure is 370-390. 4x4 tells me that front right is lower then front left.
any ideas anyone?
new pressure sensor ordered and waiting
Old Feb 21, 2018 | 08:57 AM
abran's Avatar
Sure sounds like your front right strut. Are you sure it’s new?
Based on your test there has to be a leak from the front valve block, air line at front right, or front right strut.
Old Feb 21, 2018 | 10:58 AM
Enlund27's Avatar
Cant be sure, but THE previous owner had a paper with THE order confirmation from Ebay for Four struts! THE brand is?
but i think i Will order 2 new front struts.
Advice on what brand to buy? Arnotts or bilstein
Old Feb 21, 2018 | 11:05 PM
abran's Avatar
Arnott, lifetime warranty
Ada2016
Build Threads
Jan 31, 2018 01:53 AM
Jason428sc
Nov 25, 2011 08:47 PM
yozzer
Aug 2, 2011 05:40 PM
rgrizzard
Mar 6, 2008 10:16 AM
cold_surfer
May 9, 2007 08:23 AM
