Air suspension noise of 05 LR3
Hello,
I just bought a 05 LR3 and noticed some noise of air suspension every time when the car is started.
Not sure if its the noise of some motor or compressor of air suspension system. It is loud but will be gone after 2-3 minutes.
Anyone has ideas what it is and how to fix it?
Thanks a lot !
Thanks a lot !
It's normal for the compressor to cycle on when the vehicle is started but I don't think it should run for 2 or 3 minutes. Mine (and others I've driven) run for maybe 15 to 30 seconds at the most upon startup. Someone else might chime in with a different story but as far as I know 2 or 3 minutes is long. When else does it run? Did you have the vehicle thoroughly checked out before you bought it and if so was anything wrong with the air suspension system? Is it the original compressor?
I dont think I need to adjust body height too much. If it can be disabled, it should be fine.
fastrx7man
01-28-2012 12:49 PM
tripz
01-04-2007 05:58 PM
