Alignment with a lift question
Old Dec 22, 2014 | 08:04 AM
WYRover's Avatar
Default Alignment with a lift question
So I'm planning on buying a IID tool. If I program the suspension for a lift should I get the alignment done with the air suspension set to the lift height? I read somewhere there is a "tight tolerance mode" for a dealer service alignment. I would think I would want the suspension set at the height I will be running the vehicle on a daily basis but maybe the increased ride height won't effect the alignment. Don't know for sure. I just purchased new tires and the vehicle was pulling to the right before I had them installed and I don't want to wear out the tires.
Old Dec 22, 2014 | 02:47 PM
Scope's Avatar
I bought an IDtool as well.I thought long and hard about it and decided that I will lift it only as needed.A two inch lift had a effect on the steering so I would say you would want it aligned at the height you choose.
Old Dec 22, 2014 | 11:20 PM
WYRover's Avatar
So if its aligned at the new height should the stock alignment specs be used?
outdoor7or24
Dec 1, 2013 01:19 PM
AdrenalinPlease
Sep 7, 2013 10:05 PM
bcbp
Jun 29, 2012 08:40 PM
jayzoid
Nov 2, 2011 05:37 PM
RAYMAN975
Mar 14, 2011 03:23 PM
