All terrain tires '08 HSE 19's, please help
Old Jan 13, 2014 | 09:07 AM
rfitterer's Avatar
V6 powered LR3 5315#
V8 powered LR3 5425#
Difference of a 110#
Old Jan 13, 2014 | 11:17 AM
bbyer's Avatar
Default the engine numbers can be interesting
I know the Ford Cologne V6 is a better engine than one might think. In fact, both engines are pretty good.
As such, I dug up some numbers and also a couple of Wikipedia links to each engines history.
I note that the hp and torque numbers in the Wikipedia articles vary a bit from the data I found in some LR material.
Ford Cologne 4.0 SOHC V6
Configuration 60 degree V6
Maximum power156 kW at 4750 rpm 209 hp
Maximum torque 346 Nm at 3000 rpm 255 lbf-ft
Displacement 4009cc
Stroke/bore 84.4mm/100.4mm
Compression ratio 9.7:1
Firing order 1 4 2 5 3 6
Oil capacity 6.4 litres
http://en.wikipedia.org/wiki/Ford_Cologne_V6_engine
Land Rover / Jaguar 4.4 V8 (AJ-V8)
Configuration 90 degree V8
Maximum power 220 kW at 6000 rpm 295 hp
Maximum torque 425 Nm at 4000 rpm 313 lbf-ft
Displacement 4.396 litres
Stroke/bore 90.3/88.0 mm
Compression ratio 10.50 : 1
Firing order 1 5 4 2 6 3 7 8
Engine weight 208 kg (approx.)
Oil volume 7.5 litres (wet)
http://en.wikipedia.org/wiki/Jaguar_AJ-V8_engine
lazerbrains
LR2
30
Apr 24, 2013 07:16 PM
howido213
Mar 9, 2012 04:51 PM
deucedaprodeuca
Nov 2, 2009 09:58 AM
texmanmoore
Apr 2, 2009 07:44 PM
DV57
Oct 8, 2008 02:45 PM
